Correct rim size for my truck
Hieneken49
Well, the rim in the pic is a 5-bolt pattern for a Ford...but I assume you just posted that so we could see what they look like. The specs in your link are correct....the 17x9 size with the 6x5.5 bolt pattern (or 6x139.7) is what you want. However, that -12 offset may cause problems for you. The factory offset is +31mm, which tucks the rims inside the wheel wells...so the -12 is going to stick out quite a bit, and may cause your tires to rub. I have +25mm 17x8.5 rims on my truck, and my 285's rub my mudflaps when I back-up with the wheels turned. If you don't want to trim, find rims that have a positive offset.
how much trimming do you think would be needed? and yes i only the posted the pick to show the style.
    appletrav
    appletrav
  • Who's Online   4 Members, 0 Anonymous, 809 Guests (See full list)
