2011 Silverado 2500HD Differential failure
Keelay
I have a 2011 Silverado 2500HD. I just had the front differential rebuilt due to what was stated as internal failure. Apparently it was quite a mess inside and had been the cause of most of the noise I heard in 4WD. I took the truck back 3 days ago and noticed that the noise was almost completely gone. About 5 miles down the road I started to feel a pulling as if my emergency break was on (it wasnt). There was a very loud grinding sound and it became almost impossible to even make a routine turn onto a road, even at speed. The truck would go from 25 to stopped unless I gave it plenty of throttle. This has never happened to me on any 4WD vehicle and is definitely not the normal tug you get while parking a vehicle in 4WD. I noticed that there was fluid leaking from the bottom of the truck and could actually smell in through the cab. I was told that a rear seal had blown, yet the truck is still being looked at. My question is what could cause this problem to A: happen in the first place and B: how could these differential problems effect other parts of the vehicle? I took a look underneath the truck and noticed two small circles, one was cracked and the fluid was leaking from there. I am not sure what part it was but I am looking for any answers or help with this problem.
hows that sour taste in your mouth?
all i can say is that diff got past the quailty control guy at the diff factory somehow unless you boony bashed it but i doubt you did
as for the rest of the powertrain,it loaded up the t case pretty good ,5 yr warranty is along time
rear seal is the pinion seal and when bearings go for a crap it leaks there
Thank you for the reply. As of today GM has yet to get back to me with the problem or any diagnosis. I am starting to get very curious as to what is going on. It seems like 3 days is an awful long time to take apart and find the problem with my vehicle. I did call this morning and was told that nobody had an answer as of yet.
  • 2 months later...
Front differential (rear seal) was replaced and I was told that the truck was driving stiff because of the tires. That is complete BS. As of now, if I am in 4wd I have to have the pedal to the floor to accelerate forward or reverse. Terrible noise coming from the wheel well as well as under the truck again. I smell hydraulic fluid every time I shift into 4wd as well. I am not sure if the rebuild of the differential wasn't necessarily the problem? The whole truck feels like it binds up, regardless of road conditions or turning. The brand new ones dont do this, and mine hasn't always been like this so I know it is not "normal".
Any thoughts?
From the maintenance reports they have only diagnosed the front differential as the problem. I will say that the transfer case and drive shaft look like they were just replaced. Maybe the aluminum just looks that nice, but it seems after 2 winters in New England they might be a little bit dirtier.
I am looking up stories of this same problem in older models and it seems like the issue doesn't just go away with multiple differential rebuilds/repairs. Kind of unsettling.
I have a 2008 and only in 4x4 low does my front end tend to bind up in turns only. But that is nature of the beast
You have a problem, my truck does make any extra noise in 4x4 nor does it make any odors in 4x4.
Granted you have an 11 the drive train is not too far different from my truck.
Good luck, maybe take the service writer for a ride in yours and then one off the lot so that they can compare yours to one off the lot.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   3 Members, 0 Anonymous, 1,260 Guests (See full list)
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
