Best After Market Headunit
scz71864
Im looking to change out the head unit on my 11 silverado, non bose. i have the 60/40 bench set up. Is there anything else recomended other than the advent head unit that others have. i want to keep a lot of my factory things like xm, and blue tooth, as well as my steering wheel controls
Not sure if you have done any research on the Advent unit, but it allows you to keep your bluetooth, XM, and Steering wheel controls.
There is the Rosen......but that unit has had nasty reviews............
Also Kenwood is a nice unit....uses Garmin navigation
With full aftermarket units like the Kenwwod ...Pioneer...etc
You require a bunch of modules to get everthing to work....even with that .....your vehicles features
might not work to your satisfaction
And ,, some dont mind this....but they look aftermarket...The Advent is just pulg and play
No modules req...and nothing is lost...as it was designed by Audiovox specifically for your Silverado
Good luck in your hunt !!
T
There are alot of ways for you to keep all of that. The advent unit is the only one i know of where its all included. I got a pioneer avh-4300dvd. I got the add on xm tuner so its integrated with the unit, the PAC OS lets you retain alot of the factory functions and theres a pac unit for factory steering wheel controls. The pioneer unit also has an add on for navigation and bluetooth.
    Sothpaw27
    Sothpaw27
  • Who's Online   5 Members, 0 Anonymous, 696 Guests (See full list)
