2010 stock radio usb?
Just wondering if ALL stock 2010+ radios have the usb port in the back of the radio?
Thanks.
ok thanks. I wasld to believe that all radios did,and the usb port extension by thecup holders was a dealer installed option.
No they do not ALL have them. What trim package does the truck you're asking about have? And by cup holders, do you mean in the center console of a full floor console?
LT and up trim levels have the port; on trucks with the full length console it is in the main compartment on the back wall, on trucks without bucket seats it is on the dash. If the radio has USB the port is installed from the factory.
Good info thanks. I have a GMC SLE All Terrain 2010 with the stock non bose radio. I was going to install my own extension cable from the mini usb on the back of the rdio if it was there. Good to know before I went to the trouble of pulling my radio out.
I have the same thing...'10 SLE All Terrain and as stated by skicrave you can find it in the main compartment of the centre console on the back wall just above the 12V power supply.
Just went out and looked....Just a black plastic insert where the usb hub should be :-(
I'm guessing it depends on when the truck was built, yours is probably a very early 2010 MY. May be worth it to pull the headunit out to check for a port, maybe it's there and they just didn't have the insert for the console from that vendor yet.
    Sothpaw27
    Sothpaw27
  • Who's Online   0 Members, 0 Anonymous, 548 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
