a/c not working
bell_man
Its not a truck but was hoping someone could help. A/C compressor is not kicking on. Check all fuses and relays. The line has pressure but cant get a good reading because the compressor is not cycling. with the engine off the pressure is reading at 100 PSI is this right? i cant see if the compressor has a switch i see wires going to it but a support is blocking my view if the whole thing.
so is there a switch on the compressor or is it built in?
is the systen suppose to read 100psi with the engine off?
what could cause the compressor not to kick on beside the fuses and relays?
2005 Chevrolet Uplander my wifes car.
Thanks.
    Fishboat
    Fishboat
  • Who's Online   1 Member, 0 Anonymous, 525 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
