SES lite code 32, now codes 33 and 45?
The truck is running fine, but I got an SES lite and code 32 (which is EGR valve). I swapped out the original rusty 159K miles EGR valve. Now I get an SES lite and code 33 (MAP sensor) and code 45 (O2 sensor rich). The truck runs just fine. I disconnected the battery for 6-9 hours and still get the SES lite after 5-45 seconds after start. Any ideas? I did use “old school” rubber vacuum line to from the MAP sensor to the new EGR valve as the old hard line did not fit. I have a spare MAP sensor I could throw at it…any ideas? I have driven the truck about 69 miles with the SES lite.
Cheers,
JG
Update, Truck is fixed, SES lite is out. Before I started throwing parts at the problem, I double checked all of the lines with a nice bright worklight--sure enough, the vacuum line from the MAP sensor to the throttle body was off. I must have done it when I replaced the EGR valve. The 33 code was telling me that something was wrong with the MAP and the 45 code was due to the computer going full rich due to no MAP input. Just goes to show, when you "fix" one thing and get unrelated problems, check your work area to see what you bolluxed up...
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
