Wheel well to wheel well side steps
I currently have the GM side steps but I am starting to consider swapping them out for a side steep that runs from wheel well to wheel well. I like the n-fabs well enough but wanted to know if anyone has run across any other steps that run wheel well to wheel well?
Don't know who makes them but my buddies dad has a 2011 2500 Silverado with dominators. They are wheel well to wheel well with hoops that drop down. They have a 3rd hoop right in front of the rear tire to allow easier access to the front of the bed. I really like them.
Funny, I was just thinking of something like that yesterday. My wife has trouble getting in and out of the truck, and I've been resisting getting steps. BTW, I have a regular cab, and wonder if steps from an extended or crew would work. Maybe I need to take measurements.
Lou
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 393 Guests (See full list)
    • 2013 5.3 still to this day calls for the PF48 filter.  Which as a 15psi bypass pressure.     There is a TSB, 17-NA-157 that talks about the PF-63 and PF-64 filters which have a higher bypass rating of 22psi.    TSB HERE - temp.xml   "Beginning in 2012, the oil pumps began to regulate main gallery feedback instead of pump out pressure. This means that the oil pump now does not begin to regulate until pressure is built up to the main gallery. This change reduces the amount of time it takes to provide oil to the engine bearing and lifters during extreme cold start conditions.  Main gallery feedback oil pump control systems are present on the following engine families which use Spin-on oil filters: Small Gas Engine (SGE), Large Gas Engine (LGE), High Feature (HFV6) Gen2 and Small Block Gen5 gasoline engines. These engines with the main gallery feedback oil pump control systems are factory built with an ACDelco® oil filters"   It also calls out what engines use those filters.  The gen 4 small blocks were not on that list (LMG, LC9, L9H, L92, L94, L20, L96).  Gen 5 small blocks use the higher pressure filter.
    • To me it honestly makes zero difference what filter you run. It's not a race engine, just a truck engine that's mostly bumming highways and it just needs a filter that filters oil.   The filter used to be a 7060 and the long version was a 7045. Now it's the newer updated filter that the K2XX trucks and newer run, the 100255 I believe if we are using napa numbers. Any of those filters is going to do the job.   I wouldn't overthink it, to me it makes no difference because those first filter numbers worked for 18+ years before the spec suddenly changed.
