How to hook up radio cut out for reverse
I am getting an 06 chevrolet 1/2 ton for my employee that for all the times I tell him he refuses to turn the radio down before backing up.. (He is a great employee but not a good driver)
Is there such an item to set up the radio to be cut out when you shift the truck into reverse?
Maybe off the wiring for the back up lights.
Any help would be great.
Grab a relay from an autoparts store with NO and NC contacts and use the NC contacts. Wire the coil into the reverse light circuit. Use the NC contacts in series with the power lead for the radio. When truck is in reverse = no power to radio. Total cost less than $10, plus your time.
Thank you! Could you please let me know in a little more detail how to do this? Or should I leave it to a professional?
I am quite handy, but don't want to mess anything up.
Wiring diagram is probably your best friend on this project. If you are not comfortable around schematics find a budy who is and offer beer and/or steak, or go to a professional. A competent custom high end audio installer should be able to figure this out with the proper schematics. Just be careful as I would bet your truck uses the ECM or BCM to power the reverse lights, if you short that circuit, "it would be bad". So a fuse inline with the relay coil (the relay contacts will be fused amply by the radio fuse) is a must. Also, since the ECM/BCM is probably the power source, make sure the relay has a "surge" or "blocking" diode across it to keep the relay transients from getting back into the ECM/BCM output. IIRC, those little Bosch relay kits you get at the autoparts store have one built in, they usually show a little rectangular symbol across the relay coil if they have this diode/snubber. You also do not need a huge 30+A relay, check your current radio fuse, if it is a 10A,then get at least 15A or so relay would be fine. I reccomend a smaller relay because they have smaller coils that take less current.
What you are doing is simply paralleling the relay coil with the reverse lights, so the relay coil has to go in that circuit somewhere. Since the relay coil would be switching the power lead to the radio (usually the red lead in the harness at the radio, or at the back of the fuse block), having the relay in/near the dash would be best. The reverse circuit will be the harder to find, the radio circuit is a piece of cake -- its at the radio harness and behind the radio fuse! Just the NC (Normally Closed) contacts in series with the radio power lead. The NC contacts will show closed or continuity when checked with a meter when the relay is at rest/unpowered. So in short (no pun intended) you will be cutting and splicing the NC relay contacts into the positive power lead to the radio. Compare this to the relay coil which will probably (check your schematic) have one side going to ground and the other side going to the 'switched' reverse circuit fromthe ECM/BCM.
Oh yes, you can find what you need here (Ive checked):
http://www.gmupfitter.com/body_builder_manuals.html
I can only assume it is accurate, be sure to check against what you actually measure with a meter.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 654 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
