WTB Silverado Tailgate (White)
Looking to buy a white Chevrolet Silverado Tailgate for the newer styles bodies (2007-current). Prefer it to be like new with no dents/scratches. I am located in Socal. Thanks.
You can mail me your black one and ill sand,prime,paint, and clearcoat it for 30$.
Sent from my BlackBerry 9650 using Tapatalk
Too bad shipping on your tailgate to TX would kill the deal I could get. I'm looking for a damaged one to shave and would only need the shell, not the latches or anything of that nature...
    Brendan C
    Brendan C
  • Who's Online   3 Members, 1 Anonymous, 1,035 Guests (See full list)
