Power window switch replacement
limpalong
The driver's side switch for the passenger power window is going bad. The window motor is fine, since the passenger side switch operates the window fine. On the driver's side, it's getting to where you have to push it two or three times to get it to go down. Once it goes down, it will return up easily. I believe it's the switch and want to replace it.
What kind of a project is replacement of the switch only?
edit... It's a 2008 Silverado, extended cab
Front Side Door Window Switch Bezel Replacement
Callout
Component Name
Procedure
1. Pull upward on the switch bezel assembly to disengage the retainer clips from the door trim panel.
2. Disconnect the electrical connectors.
If it is the switch, it should be a easy swape. The panel holding the switches should pull right up with your hand and then unplug from its harness.
