Hard to start '03 Silverado
My '03 Silverardo 5.3 is no longer a turn key start. It doesn't matter if it's hot or cold. I turn the key off and turn the key again and the truck starts instantly every time. Truck runs perfectly other than that. Has 345,000 kms and everything is original.
Fuel filter
fuel pressure regulator
Fuel pump
Remove the vacuum line at the FPR. If fuel is present, replace the FPR
Take a pressure reading. Key on, engine off. Record pressure. Should be 55-62 psi. When pump stops operating, pressure should stabilize, then remain constant. If it drops more than about 5 psi in about a minute, you've got a bad check valve at the pump. Requires pump replacement.
    appletrav
    appletrav
  • Who's Online   3 Members, 0 Anonymous, 802 Guests (See full list)
