HVAC issue
2003 Yukon SLT. Electronic HVAC system. The fan control to increase the fan speed is intermittently not increasing the fan speed as it is turned up. What do I need to check or replace?
Thanks.
check your htr fan resistor under passenger side dash,look close for discoloured wires/melted connector ,,,
do a search here for the same ,lots of topics on it
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
