2500 Air Bag Install Check on Parts?
I just got the following kit.
http://www.firestoneip.com/site-resources/ride-rite/installation/2253.pdf
The instructions clearly show a single hole in the lower bracket to mount the bracket to the under side of the air bag. However, both brackets that came with mine have two wholes. If i use either, the air bag won't be centered on the bracket and would shift more toward front or rear?
Anyone run into this and/or know if a) two holes are correct and b) if so, should bags sit toward front or rear of the bracket?
thx
-brad
FYI: just from trying to fit, it turns out you use the hole towards the front of the vehicle. the lower plate still doesn't rest center on the pad.
Ran into three issues during install (well those not mentioned in manual):
1) had to cut one of the upper bracket corners (else it wouldn't fit with the gas tank)
2) the factor bump stops for the springs were more work than the instructions implied: "single tack weld, just bend back and forth to break"), I chose to grind the weld for the bracket and even after that, the plate wouldn't contact the main frame because the riser block (betweeen frame and stop bracket) interfered with the height of the bolts. I could have cut the bolts, but i chose to cut a string off the riser.
3) driver's brake lines is right in the way of the lower mounting bracket on the axle. Ideally i need to have this reshaped.
    DM22
    DM22
  • Who's Online   2 Members, 0 Anonymous, 2,479 Guests (See full list)
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Monday looks like a good day for the dealer to test an ac issue. Hopefully it all turns out good.
    • Paid $2.72 for E85 today.
