BedRug bed liner 2011 Silverado 2500/3500
BedRug bed liner. Fits 2011 Chevrolet Silverado 2500 HD SWB 6.6' bed. Should also fit 3500HD and 2012 and 2013 year models. Part number BRC07SBK.
Excellent condition, used for 9 months ~4,000 miles. Kept in garage 90% of the time and covered by tonneau cover. Only carried small square bales of straw and boxes. New $399.95, now $285.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
