Possible rear axle seal?
I was adjusting the parking brake on the truck. First time I've actually removed the rear wheels since I bought it with 213k in 2011. I removed the rotors and saw the pass. side was oily and had a bit of grease. The drivers side was dry just brake dusty.
Now either the PO got sloppy with the caliper grease or the seal is leaking. I have never seen anything drip out from behind the brake while parked. This makes me want to check the diff fluid level asap.
Try to smell the oil you see. Diff oil is very distinct in smell. If it is diff oil, about the only source is the axle seal.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
