Bed rock guard removal
I am looking in to removing the pieces of clear tape that are on the bed to protect from rock chips. Might leave it off or I might replace it because it is pretty tore up. Any tips on getting it off?
Heat it up with a steam iron or steam cleaner (sort of like this one...http://www.drugstore...9a-8d9e46da84b8) and peel it off slowly. It will probably tear when pulling it off but it will come off using steam. When I had the windows on my dad's '11 3500 Denali tinted, one of the guys at the tint shop ran into the door frame of the shop when trying to pull it into the shop. It tore the tape, but didn't scratch the paint one bit. The owner of the shop used a steam cleaner similar to the one in the link to remove the damaged tape.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 703 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
