Pictures of My Truck
95_2500HD
Hi, i've been browsing this forum for a while now and I thought I would join and post some pictures of my truck, so here is a link to a little website I made:
http://0ryan0.home.mchsi.com
The truck is a 1995 Chevrolet K2500 (8600 gvw) regular cab long box with a 5.7L (350ci) engine and 4WD.  I bought it about a month ago and it now has about 63,000 miles on it.  I use it as a work truck for a lawnmowing/landscaping business and also to plow.
Options Include:
-4L80E Auto Trans.
-4.10 limited slip rear axle
-Plow Prep Package
-Heavy duty front springs
-Heavy duty transmission cooling system
-A/C
Accessories include:
-EZ-dumper (came with truck)
-7.5' Western Pro Plow (came with truck)
-Husky Floorliners
-Husky Mudflaps
-DeeZee bedrail protectors
Want List:
-LT285/75/r16 bfg all-terrain ta-ko
-nerf bars
-(the list goes on)
Thanks.
I have a question:  What type of exhaust would work well on this truck?  The pipe from the cat to the muffler is shot, the muffler is rusted through, and the rest of the pipe is gone.  I am thinking of just putting two pipes out the back from the cat with no muffler (it sounds pretty good the way it is now :smash: )  Any suggestions would be appreciated.
Now, that's a T-R-U-C-K! :smash:
I have a question. When you are plowing snow, does it ever start to build up so that it stops you or really gets hard to push?
Actually, I havn't had the chance to plow with this truck yet.  It's January 13th and still NO SNOW ???
But to answer your question, I don't think it will ever build up enough to stop the truck because the plow is not boxed in (it would go the the side), also you can windrow it.  If there ever was that much snow to stop the truck, you could plow it in layers by having the plow raised.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   0 Members, 0 Anonymous, 1,299 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
