07 install backup camera
I have a 07 gmc grewcab thats has the factory navigation with the dvd player and it also has the rear seat dvd entertainment sys i whould like to install a backup camera that goes on the tailgate. my ? is did my truck come with the pre wire harness under the bed of the truck for the backup camera i look and i did see a harness that was plug off on the frame rail next to the spare tire it looks to be a 2 or 3 wire plug how can i tell if this is it or not. if it not pre wire what will i need to get the backup camera working
Thanks
    rayredbone
    rayredbone
  • Who's Online   2 Members, 0 Anonymous, 463 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
