Swapping Exhaust Q???
Im buying a new truck on Monday, and I have already compiled a list of parts that I will be taking off of my truck and putting on the new one. im pretty sure most of them will swap over, but I was wondering if the exhaust would. Anyone know if the exhaust system would be the same on a 2007 Silverado Classic Crew as it is on a 2005 Silverado Ex Cab? Both are 1500, Z71, with 5.3s.
It's got the flange-type connection from the cats, so it ought to swap.
A good muffler shop can make it swap, for sure!
The wheel base is the same for both trucks so it shouldnt be a problem
Yeah, but they want money for stuff like that. :D
That was my thought, but I know they do some strange stuff at the manufacturer sometimes.
Well I know my MBRP from my 04 extended cab swapped over to my friends 06 crew cab. Both 2wd 4.8's
Thats what I needed to know.
Check a couple of aftermarket systems for both trucks to see if the part numbers for the two trucks/kits match up.
Good idea. Why didnt i think of that? Ill do that to double check.
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
