92 sierra drivers exhaust manafold R&R help please
i HAVE A 92 SIERRA K2500 5.7l AC AUTOMATIC WITH A CRACKED DRIVERS SIDE EXHAUST MANAFOLD. TAIL PIPE BOLTS ARE OUT ALL EXHAUST MANAFOLD BOLTS EXCEPT FOR THE FRONT 2 WHICH HAVE A BRACKET IN FRONT OF THEM THAT SUPPORTS THE BACK OF THE ALTERNATOR AND THE POWER STEERING PUMP. THERE IS A BOLT ON THE BACK OF THE POWERSTEERING PUMP THAT IT APPEARS AS THOUGH I HAVE TO PULL THE PULLEY OFF THE POWER STEERING PUMP TO GET AT IT FOR THE BRACKET TO COME OFF AND THEN IT IS SMOOTH SAILING. iS THIS CORRECT . I HAVE TAKEN OFF THE SKID PLATES AND THIS IS THE ONLY WAY i CAN SEE IT BEING ACOMPLISHED.
PLEASE ADVISE
SPLINTER
If its a round brace with flat ends with bolt holes. Best I remember if it don't unbolt from backside of alt /power steering bracket. Maybe one of the bolts that holds P S pump will set it free if not just take the whole power steering pump off. Good Luck.
Almost forgot. The bolt you're speaking of may can be got to through holes in pulley. Hope this helps.
got it out had to rent a pulley remover from autozone and pull the ps pump pulley off to get at teh mounting bolts and it was out !! Exhaust manafold is cracked 75% all the way around. To the wrecking yard I go get a new one to put in and a new O2 sensor I am thinking with the crack and it opening up as it got warm it was making a lean code on ht eO2 sensor Shall see.
Thanks for the replys
I long for my 72 blazer where you could work on it with no hidden bolts and BS
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 542 Guests (See full list)
