Chrome Guage Bezel Rings
Its nice to have the extra two there in sight. On and did it come?
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
To me the 4 gauge cluster looks bad. At least in 99-07 w/t's through Denali's got 6 to 7 gauges.
Just do the 6 gauge swap. People on here have done it. And I like the regency because of the white face. Look at my SS gauges. White/silver
Im actually looking at this. I dont need a trans temp guage as it comes up on the trucks computer and the battery voltage Im ok not having as I will be installing another battery to run my camper off of.
http://www.sfxperformance.com/parts/NUIWG477.htm
this is my dash
Nice I was wondering if they one of those for the W/T instrument panel.
Do you plan on installing the DIC?
Sent from my DROID RAZR using Tapatalk 2
I did the white background gauge swap in my commuter car for one main reason: Sunlight. IMO, the white background gauges are easier to see in certain conditions. I would bet the truck is the same way.
Nice I was wondering if they one of those for the W/T instrument panel. Do you plan on installing the DIC? Sent from my DROID RAZR using Tapatalk 2
I have DIC with the button next to my gauges remote tire pressure, hood door open, remote door lock although I dont have power doors and trans temp. I wonder if I got the panel DIC would it have the fuel management?
Well thats one of my reasons the other I dont want the 6 cluster because of all of the illumination from it I get enough from the 4.
The DOC adds all the stuff you mentioned and sorry to beat the dead horse I just love the 6 lol
Dave I will come to Maryland and whoop your ass for that. Only do it of your blown. I'm sure A pro charger will be added later
    fourhorses88
    fourhorses88
  • Who's Online   4 Members, 0 Anonymous, 875 Guests (See full list)
    • I figured you would know about it.
    • It added a cost layer to an already limited production supply. True that.
    • Swap costs and supply/demand balance. When a barrel comes out of the ground the entire range of products are present but not all at the same percentage.    Breakdown of Refined Products The following table summarizes the approximate output from a standard 42-gallon barrel of crude oil: Product Type Gallons per Barrel Percentage of Total Gasoline 20 gallons 45% Diesel Fuel 9 gallons 21% Other Products 13 gallons 31%   Most of that diesel figure is 'straight run' or cut from the barrel. Gasoline 'cut from the barrel runs 0 to 20% at the crude. So in the crude unit there is more diesel the gasoline, usually.  The full refining experience however gives the tabled values. Ego there is half the diesel than gasoline after the 'first crack' That could be an FCC unit, or Isomax or....   Those units take heavy products and break the big ones into little ones. Those numbers are harder to get hold of but directionally it ends up the same.    Really light products are very profitable. Ethylene and Propylene to name two. Those are cracked from slightly heavier feeds like NG and Propane and Ethane. The cracker harshness determines the feed for distillation. Those feeds come from less profitable products like diesel and gasoline.    So...there is a swap cost. How much market is there TODAY and what crude am I running TODAY..... what is my process capable of always.    There is this as well. The USA uses allot more gasoline than it does diesel so in the cracker the process is tilted to gasoline production which....limits supply of diesel. OTR uses the most and it has different requirements than automotive and agricultural.  Limiting auto products.    You are correct however. It is less refined, just less of it. Allot less.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
