2" RC Leveling Kit and Ball Joint Issues
Would someone explain the benefits of a liftkit to me??
I know the pro and cons of a 6" lift, been there done that, and now back to stock. I hated the gasmilage to be honest. It drove me crazy not being able to drive more than 100kmh/60mph because of the gasneedle going down in seconds.
Im assumi9ng the gas mileage was bad because of tire size not the lift itself?
Bruce,
to be honest I don´t really know if it was the lift or the tires. All I know is it was out of space when compared to stock...but I still do not regret any second of having this lift built in for two years. Felt like king of the road in this rig :pimp:
    rayredbone
    rayredbone
  • Who's Online   0 Members, 0 Anonymous, 509 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
