Looking for a DD need a VIN. Anyone help?
Knowklew
Hey guys I am looking to get into a DD vehicle to cut down on the mileage of the truck. Plus being around Chicago, the gas prices here are just plain stupid.
So if anyone can run a VIN for me, that would be great.
You can PM me if you would rather not post on the boards.
1G1AP58X697133714
We are not allowed to run them anymore, have the dealer pull the GMVIS for you
My service adviser did it for me. Pulled the build sheet and complete history of it for me
I think he was looking for a carfax
Sent from my SCH-I535 using Tapatalk 2
The GMVIS will pull all the times it was in the dealer
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,336 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
