will a cold air intake void my warranty? i have a newer GM and didn't want issues with the warranty.are they legal in most states? someone said they need to be CARB compliant?
Will not void warranty. They are legal. The only people who need carb compliant is california
Sent from my Samsung GS4 using Xparent Red Tapatalk 2
i guess CT adopted the CARB rule also, so I'm screwed. Most units aren't CARB compliant. my buddy has been holding off doing his challenger because of it.
Most of the top cold air kits come with a CARB exemption sticker. My volant has one, my K&N did. What is your truck year/make/model/engine and I will find you one that is exempt and will be legal
K&N, Volant, Airaid would be my personal picks in no special order, all are CARB exempt and come with the sticker. I personally run the Volant
Yes, if they are using CARB regs, you need the sticker. It is what they look for when doing the visual test. Here is what mine looks like. All the big companies paid to be accepted by California and the right to give you that sticker. Doesn't matter the car. If you are curious if a particular intake is exempt or not call them and ask. To double check ask them for the Executive Order number and run it through here
http://www.arb.ca.gov/msprog/aftermkt/devices/amquery.php
Here is my sticker for the intake
If you run that D- number on that site I gave it will reference for what vehicles that number is good for.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,201 Guests (See full list)
