'13 Silverado Onstar, Bluetooth, USB
Traded in the ol' '07 GMC and picked up my '13 Silverado last week Nice truck and steps above the WT model.
Wondering if someone can answer a couple of questions on the Onstar/Audio system.
Once my 3 month trial of Onstar expires, do I lose Bluetooth capability in my audio system? Not really interested in keeping Onstar.
If I pull my factory radio and install my Kenwood (DDX470), do I lose functionality of the dash mounted USB port, or is it something I can connect up to my unit?
And last, does that microhone in the headliner have any functionality outside of Onstar, i.e., is it able to be plugged into my unit as well?
On my old truck, I just needed a harness, and a LAN adaptor and everything worked fine. That was a work truck though, and had no bells n whistles. This new system seems to be a bit more sophisticated and I'm wondering if all this stuff will work or not.
Thanks for any suggestions...
1. I believe blue tooth still works but not 100% sure.
2. same answer as 1.
3. If your talking about the little round grille above your shoulder that isn't a microphone but a ambient temp sensor.
Sent from my DROID RAZR using Xparent Green Tapatalk 2
Thanks man... The temp sensor thing makes sense. I thought it was the mic for bluetooth. I guess I'll wait the 3 months and see what happens - unless someone else chimes in. Installing the head unit, 6 speakers, and amp with all the wiring was no easy task (and a pain to get outta the GMC), and I'm to the point now where the bells and whistles are good enough - I can get by without the premium sound (old guy here...)
Your speaker for onstar/bluetooth is by your over head lights if I remember right. As for onstar no you don't have to subscribe to it for your Bluetooth. The factory radio I'm sure plays apart of the Bluetooth though as you can control the volume of the call but when the Bluetooth is activated it dims audio and lowers the a/c blower so this all could be plugged in somewhere else
I think that's another adapter you have to have to retain the steering wheel controls - that controls all that other stuff. That, along with the LAN adaptor to retain onstar functions (and everything else that goes with it) AND, the relay necessary to keep the turn signal chimes, etc. I'm sure I'm not the only one on here who's had a full blown audio system installed. Hopefully someone will chime in and give their advice. I hate to go to an installer and bug them about this stuff.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
