wiring diagram
Would anyone know where I can find a wiring diagram for my 2011 1500 taillight? I purchased led cargo lighting and want to wire into taillight 12v hot. I will install switch in bed of truck. can not believe it is so hard to find diagram. Trailer hitch wiring diagram would also work too. Thanks.
Ok so I installed my Truxego B light cargo LED. I was actually very impressed with how much light they give off, really light up the bed at night. I was able to get power from taillight. I installed switch in bed of truck (bought different switch at Radio Shack). Right now I am happy with how it works but if I could I would tweak it just a little bit. Currently I need to turn on lights in cab from auto to on, once they are on I turn on switch in bed and they come on and work great. I was wondering without going all the way back to battery how can I always have switch in bed hot so that do not have to use switch in cab and if truck is off all together and even locked can use light switch in bed? I watched a install video on youtube and said wire to taillight was always hot but did not find that the case on Silverado. The wiring diagrams above were not easy for me to follow so maybe the info is on there but I could not read it.
Thanks
the only juice back there that is B+ is at the trailer plug
with the key out of ignition ,check all terminals with a test light,
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
