If you are a K&N oil filter user and your vehicle calls for an HP-1007 you can also use an HP-2006 which is a longer filter. There is plenty of clearance, HP-2006 dimensions are identical to HP-1007. So a little piece of info. if you are looking to increase your filtration media over 1" and pay the same price.
Part HP-1007 Product Specifications
Product Style: Oil Filters
Anti Drain Back Valve: Yes
Bypass Valve: No
Filter Material: High Flow Premium Media
Gasket Material: Nitrile Rubber
Height: 3.75 in (95 mm)
Outside Diameter: 3 in (76 mm)
PSI Relief Valve: None
Removal Nut: Yes
Style: Canister
Thread Specification: 13/16 In. - 16
Removal Nut Size: 1 inch
Weight: 0.75 lb (0.34 kg)
Product Box Length: 3.25 in (83 mm)
Product Box Width: 3.19 in (81 mm)
Product Box Height: 4 in (102 mm)
http://www.knfilters.com/search/product.aspx?prod=hp-1007
Part HP-2006 Product Specifications
Bypass Valve: No
Height: 4.781 in (121 mm)
Removal Nut: Yes
Style: Canister
Weight: 0.84 lb (0.38 kg)
Product Box Length: 3.19 in (81 mm)
Product Box Height: 5.75 in (146 mm)
http://www.knfilters.com/search/product.aspx?prod=hp-2006
So any 2003-2007c with a 4.8, 5.3 or 6.0 this applies to. Double check your year and model to confirm. These are the only years I'm positive this works for.
:thumbs:
Is this for to change your gen 3 to the 6 cyl Trailblazer filter? I do that with my M1 filters
I'm not sure, I just know that if your vehicle calls for a K&N HP-1007 you can use a HP-2006 instead with more filtration media for the same price and no clearance issues.
Just looked. So for all you Gen 3 4.8/5.3/6.0 guys like Aaron and myself, you can use the 2006(my search) 4.2L Trailblazer oil filter and get this result. Just a little more filter media.
    ar0517
    ar0517
  • Who's Online   3 Members, 0 Anonymous, 761 Guests (See full list)
