nav upgrade
kdubbs
I have an 07 sierra denali with nav looking for something with bluetooth streaming dvd playing an some apps.. i thought the ogm 1 was gonna be it but found out its not compatible with 07 . So looking for a little insight thanks
Surprised the OGM-1 is not compatible with 07.
I wonder what is different?
I have the OGM-1 my wife has an older Kenwood.
If you use navigation, my next choice would be kenwood.
The reason it's not completely compatible with the 2007 Denali are twofold: I would guess that your truck has the Centerpoint system unit from the factory (if you have the center dash speaker, that tells us you have Centerpoint), and if it does have that system you will need a data module to allow the OGM1 to turn on the factory amplifier. This results in a couple of unintended side effects: since the OGM1 supplies chimes and turn signals and the Centerpoint system amplifier provides them as well, you will have double chimes and double turn signals through the system and no way to easily change it. The other side effect is that on 2007 model year trucks, we cannot guarantee that the rear console controls will work for the OGM1.
Having said all this, we have done three dozen OGM1's in 2007 Denali's and I only know of a couple of people that were unhappy with the result. If there are any owners out there that have this combination, I would encourage them to chime in to give you their opinion of the system.
I know that when you with the OGM1 up against any aftermarket back in this truck or any other NBS truck, the OGM1 comes out as probably the best option no matter what...
Well thanks for input ogm 1 was my choice too and i bought one installed it and had no sound at all thats when i made the call to advent and they gave me the bad news.. i since have sold the ogm 1 didnt think i had a chance to get it to work.
I didnt lose any money on that unit will consider it again if other guys have it up and running. would like to know which module i need if possible and cost for it
    zibzer2
    zibzer2
  • Who's Online   3 Members, 1 Anonymous, 799 Guests (See full list)
