No DVD Audio over car speakers
GMCrat
I have a 2004 Denali XL that has the full bose system including disk changer, NAV and rear dvd with headsets as well as the wired headphone jacks on the rear seat audio controller. According to the manual you are able to play the audio from a dvd playing for the rear passengers over the car speakers. Here are the instructions.
Audio Output
Audio from the RSE system DVD player or auxiliary inputs may be heard through the following possible sources:
Wireless infrared headphones
Vehicle speakers
Vehicle wired headphone jacks on rear seat audio controller (if equipped)
The RSE system will always transmit the audio signal by infrared to the wireless headphones, if there is audio available. The RSE system is capable of outputting audio to the vehicle speakers by pressing the CD button on the vehicle's radio. The RSE system may be selected as an audio source on the radio if the RSE system power is on. Once the RSE system is selected as an audio source on the radio you may adjust the speaker volume on the radio to control the volume of the audio to the speakers. If the RSE system power is not on, the RSE system will not be an available source on the radio head unit. Please refer to the operating instructions for the vehicle radio for more information on its operation.
The RSE system is capable of outputting audio to the wired headphone jacks on the rear seat audio controller if the vehicle is so equipped. The RSE system may be selected as an audio source on the Rear Seat Audio controller if the RSE system power is on. Please refer to the operating instructions for the Rear Seat Audio Controller for more information on its operation.
The problem I have is there is no RSE showing on the radio or if I press the CD button it will not switch to or show RSE. I have tried having no CD's in either the deck or the CD changer but no combination seems to work. I also have the remote but there are no choices on it that have helped. The headsets work fine but I have not tried the wired headphone jacks. It seems like the DVD system is not talking to the main stereo.
Any help is appreciated.
thanks
Scott
Problem solved, if you have an Audiovox DVD player it is not stock and will not tie into your stock radio or at least mine is not. Thought it was stock but obviously it is not.
