Matilda Dies Mysteriously
TxDoc
Australia's first cloned ewe dies mysteriously
Last Updated Fri, 07 Feb 2003 11:45:50
CANBERRA - Australia's first cloned sheep has died unexpectedly. Independent post-mortem tests failed to identify the cause of death, scientists said Friday.
INDEPTH: Human Cloning
The merino ewe named Matilda died last Saturday at the South Australian Research Institute near Adelaide. Rob Lewis, the institute's executive director, said staff didn't find the corpse until the following day.
Lewis said Matilda seemed "remarkably healthy" on the day she died. The cloned sheep gave birth to three lambs.
He added the body was cremated because it had decomposed.
Matilda was cloned in April 2000 using a similar technique to the one that produced the world's first cloned sheep, Dolly, in Scotland.
Since the birth of Matilda, the institute has produced other clones that are apparently in good health, Lewis said.
FROM JUNE 4, 2002: Australians raise self-shearing sheep
Australia is the world's largest exporter of raw wool. The industry is worth $2.3 billion US a year.
Written by CBC News Online staff
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,262 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
