Changes to accessory wheel codes?
For anyone looking for GM accessory wheels, it looks like some of the codes recently changed. I looked at the site a couple of weeks ago and the wheels I plan on buying were CK158s. However, they are now described as CK159s. It also looks like there are a lot less options than before. Not really sure what happened, but figured it was worth pointing out.
Apologize if this has been covered elsewhere.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
