Squealing noise coming from HVAC vents
jwoodall
Hi all:
My truck is a 2009 Ext cab Silverado, and it has the auto climate control. Yesterday afternoon the squealing noise started. Seems to be from the right HVAC vent but I can't pinpoint for sure. Only seems to happen when I have the air circulating from the outside. If I turn the HVAC off, the squeal mostly goes away. Of course with it being so cold out I cannot turn the A/C on so it will not let me run with cabin circulation. Any ideas what happened?
Just taking a guess here, but it sounds like GM cheaped out on grease in the blower motor bearings.
My '85 Monte Carlo used to do that in cold weather, when it was 10 years old. Removed that vent tube & sprayed lube in there, and it was as quiet as a mouse until it got sent to the crusher.
I highly doubt the newer motors are serviceable in any way though ...
I am not a technician, but I have a similar situation going on with my 09 GMC with auto and air intake. It has been cold in Ohio too but this started in the summer and has reached a maximum annoyance level. I have read several others that seem to have issues with the blower resistor. It seems to be a recurring problem with GM trucks. I have one ordered and will be replacing it. Hopefully it will work. Once I get it in and fixed, I will report back and let you know.
The resistor won't cause a squeal - that issue causes several speeds to not work on a manual system. Not sure how the auto one is controlled - if I had to guess, it's via computer ... like everything these days.
Thanks for the replys. Another important point I forgot to mention is that the squeal is also dependent on road speed. It starts about the time I hit 40 mph. So that also leads me to believe it is related to the outside air intake vent.
    DaleB
    DaleB
  • Who's Online   4 Members, 0 Anonymous, 1,414 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
