Clear up some confusion I have. 08 Gmc Denali
So I feel like I'm beating a dead horse with this topic. However I have typed in "_in lift on 2008 sierra denali" and many other varying forms of the same question into google only to find threads on many forms that discuss this matter however they all end with no answer. Is it possible we could make this the end all to this topic? There was one on this forum that led me to believe it could be done with this kit > http://www.roughcountry.com/gm-suspension-lift-kit-269.html . I see the problem with lifting or even leveling a Sierra Denali its all about the angles, especially with it being awd. I hear there is certain vibrations when reaching certain speeds. I recently test drove an 07 Denali in which the owner claimed it had a 3inch suspension lift, and I confirmed it had 35 inch tires. However, what I could not confirm was the type of suspension lift. It had minimal vibration but I couldn't tell if it was because it had mud tires on it ( I haven't owned a truck with mud tires in about 10 years).
The reason I come to this forum with this question is because I'm in the market for a truck. I would like it to be an 07-11 Denali but I would like to put on a 2-3inch leveling kit on it and but 33's under it just to give it a nice overall look.
So would the rc kit put me where I need to be. If there are any Denali owners on here with a lifted truck enlighten me on the process of lifting one it would be greatly appreciated.
I would like to add it appears you can get away with any suspension lift as long as you use the dual cvs. Is this correct. If so whats a good kit that doesn't require cutting and welding?
thank you.
A guy here lifted his denali and had 35's. I dont remember the brand but I think it was BDS. He had done a suspension lift and body lift. He had to get I think a new driveshaft. Not sure about the front half shafts. I think his name here is christiank22. Most decent lifts require some cutting.
I'm thinking the dual cvs and the diff drop would elimate any issue with a 3 inch suspension lift. Now all I need to do is find a sd and get it bought.
  • 1 month later...
What about a level kit on a Sierra Denali, yay or nay?
    AidenVorpagel
    AidenVorpagel
  • Who's Online   2 Members, 0 Anonymous, 1,323 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
