Output shaft seal
Good afternoon,
I have a 2007 new body style Silverado 5.3 flex fuel with a leaking front diff output shaft seal on passengers side. I have looked a few online videos of the change and doesn't look too bad. Has anyone done this recently and have any tips or links to good instructional videos? May tackle this weekend, not leaking a lot just a drip here or there on the garage floor but would like to get it fixed. Also are the seals at auto parts stores worth a dam* or should I get an AC Delco seal? Any input appreciated.
Thanks,
Neither is worth a damn ... but I certainly won't install another GM one.
Mine started leaking on the driver's side somewhere between 40k-50k miles 3 years ago. Still haven't fixed it. With mine there's alot of slop, which took out the seal - I suspect a bad bushing or bearing. When people see my low mile truck marking it's territory, I just tell them that's 21st century quality for ya right there.
I still haven't fixed it .. and don't have much desire to either. Approaching 70k now.
I have done many of these, USE THE GM PART FROM THE DEALER!!! I cannot stress how important that is, the aftermarket ones are the previous poor design. GM redesigned them recently and they are far superior. As for the job of doing it, it's not that bad, lots of videos out there. Make sure to replace the bearings if there is excessive slop, a little is normal.
Well that figures. They realize there's a problem, quietly fix it, and announce it to no one - at least none of their customers.
Again ... 21st century manufacturing for ya. :banghead:
Changed it today, piece of cake to do, just put it up on ramps, didn't even have to take passengers tire off. Your right efritz seal is all new and looks a lot better. Bought a new gasket also where assembly meets the differential. All from GM. Seal was $27 and gasket about $15. Left the skid plate off to check for any leaks after driving these next few days. Glad to hopefully have this issue fixed. Used limited slip Valvoline 80W-90 to fill diff back up. Will post part numbers later if any needs them. Easy job to do.
    DaleB
    DaleB
  • Who's Online   1 Member, 0 Anonymous, 1,266 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
