What size wheels can I run?
Johnhickey20
I have a 2002 2wd ext cab chevy 1500.
I am putting a 2in rough country level kit on it.
What size wheels can I run? I think it can do up to 32 in tires but I want to know the 275/50/r20 number... (Yes I know that one probably makes no sense)
I want to run deep lip moto metals. Anyone have pics if there 2wd with leveling kits?
Thanks
Seems with a 2inch level, most will fit 285/60 or 275/70 with little to no issues. Your offset (if any) will be what will give you issues with the aftermarket rims. Google tire size calculator for what ratio number equals what height. The width will be the kicker when you get up in the height though.. Good luck.
It is not the size of the wheels that comes to mind, it is more the size of the "offset " of the wheels.
Point, I am running 22X9.5" rims with 285x45xR22 tires all the way around my 2013 Yukon (stock height), and the offset of the rim is +34mm (stock is 20x8" +31mm). I do not have any rubbing issues when clocking the steering wheel in both directions.
    ar0517
    ar0517
  • Who's Online   0 Members, 0 Anonymous, 630 Guests (See full list)
