2005 aftermarket radio question
I have 05 silverado and after I installed a aftermarket radio I have found that everything works great except for the fact that I have to have my head light switch on to power it up. If I have the switch on auto it will on work when the headlights are activated. I prob have something wiring incorrectly but I'm not sure. Any input would much appreciated.
Did you use a harness?
Sounds like you are pulling power from the wrong wire.
"From The12volt.com"
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / SILVERADO / 2005 / Audio
Radio 12v orange + radio harness
Radio Ground black/white - radio harness
Radio Ignition (Class 2 Serial Data)
Radio Illumination N/A
Factory Amp Turn-on pink + radio harness
Power Antenna N/A
LF Speaker +/- tan - gray +,- radio harness
Notes: If equipped, the amplifier is under the center console.
RF Speaker +/- lt. green - dk. green +,- radio harness
LR Speaker +/- brown - yellow +,- radio harness
RR Speaker +/- dk. blue - lt. blue +,- radio harness
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Passlock II
Part #: 555LW
Alternate Part1 #: 555T
Notes: Not required if using the combo interface module.
The Passlock II wire colors are yellow, black, and red/white (not used).
Door Lock Interface Required:
Yes Type:
Data Bus
Part #: 456G
Combo Interface Required:
Yes Type:
Data Bus
Part #: 457GW
Notes:
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed electronics, Inc. assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Thank you very much. Yes I bought a nice wiring kit. From what you sent me it looks like I shouldn't have wired in the radio illumination wire. I'll give that a try and let ya know how it works. Thanks again
    Paul Annabelle
    Paul Annabelle
  • Who's Online   5 Members, 0 Anonymous, 1,325 Guests (See full list)
