nnbs first brake job mileage
On my 2011 Chevy Silverado 1500 I have a bit over 73,000 miles and I have a ton of pad life left.(still on original tires too.) Never tow anything with this truck, Bed will see 1,200lbs at times, 90-95% hi-way and country roads.
My 2006 Chevy 2500HD has over 135,000 miles still on original brakes and I bet pad life is around 50%. Tow and haul regularly (Mostly Hi-way) Tows both "bumper" and Goose neck trailers. Mostly horses and 5,000-8,000 lbs of grain for horses.
I had enough time this morning to take a front rim off. I measured roughly 8mm of pad left. Would that be considered below spec and time to be changed? I am going to take off the rear rims to inspect sometime today and have a look where they are drum
Its time for changing when they get down to 3 mm.
My 2009 had 124,000 kms on before that happened and it was the rear that wore down first.
Just wondering how long brakes tend to last on the nnbs trucks? I have 50,000kms on my truck now and my local garage is telling me i need all new brakes and i have a nice rejection inpection sticker on my truck now. I bought the truck new in 2011, and i am difinitely not a late braker and tend to be quite easy on my truck....My father has a 2010 sierra with over 100,000kms on the original brake and he is hard on the brakes and tows trailers often.
With only 50K kilometers on the truck (that's just a little over 31K miles) I would be looking at a second opinion for the amount of brake wear. Not knowing a lot about vehicle safety rules in Canada, is that shop required to report brake condition when the brakes are checked for any reason?? I'm thinking that shop is simply looking for income. Is there a way to contest that rejection sticker? Sounds like BS to me.
As to reports of more wear on the rear brakes of trucks with 4-wheel discs, my '08 Silverado 4x4 has 4-wheel discs and at 53K miles (roughly 82K kilometers) the front pads have a good 80% left but the rears are down to 50%. I don't do any off-roading, but I do tow my enclosed car trailer (7000 lbs loaded) 6-8 times per year.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 706 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
