Fishing sites
bassdog
Well, it seems I can't copy and paste the links at once. :but!:
PM me and I'll send you a bookmark html file for the sites.
bassdog
No.  We want them here. Now.  You dont actually HAVE any fishing sites do you?  You've never actually BEEN fishing have you.  Do you even know what a fish looks like?!?!?!?
Fraud.
DOHHHH!!! So close.......the GMTC limit on links posts is 35 links.  Under that, as we all know, isn't a keeper.  You only supplied 31 links.  We had to throw it back.  Sorry.  :crazy:
I still think he is bluffing.  :crazy:
Very possible JP, very possible.  The list DID look sort of "pre-pared" didnt it?  Like it cut and pasted from ANOTHER post somewhere...or from a fishing magazine...anyone could do the search right?  Doesnt really prove anything....hmmmmmmm :lookaround:
Quote (Jpshostr @ Jan. 30 2002,8:37)
Ok,ok, you got me again. Need some help from Jon on this one... Jon, do you still have the links to my truck pictures? I have a picture of my boat in that collection. Can you post it?
I'm going to go bug my wife for fishing pictures now, I'll post some tomorrow from work.  :crazy:
Be sure to take the pricetags and wrappers off before you take the pics!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,270 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
