Door controls on 2011 Sierra Slt
MartyMGD
My Drivers door controls just quit working. All other doors work fine. Can they be reset.. Checked the 25amp breaker and its OK
Is it all the controls? Not in any way sure but on my Vette, it had a control module in the door that was common to go out and had to replaced. Easy swap out. Not saying that's your issue, if there even is a similar control module. Post a thread over here in this section, http://www.gm-trucks.com/forums/forum/3-1999-2006-2007-2013-chevrolet-silverado-gmc-sierra-1500/ and link to here or ask there. Vehicle specific forum where you'd get better help. The other quick check would ve to check the wiring through the door jamb.Try moving them around while pressing a button to see if it works. Or, if your handy with a voltmeter, that would tell you as well.
  • 4 months later...
i'm having the same problem on my 2009. The door lock will sometimes work, sometimes not. The same goes with the controls in the doors, some days it wont light up and the controls wont function, other times they will work.
I've had it into a few shops and they cant "figure it out". I'm thinking its either the wiring in the door shorting out or the module is wearing out
