Rear differential cover
ShawnR
I tow an RV at max gross combined weight. I'd like to replace the stock diff. cover with one with cooling ridges and perhaps a little extra capacity since it gets hot. Any suggestions are welcome. I'm trying to not spend $250 for the mag-hytech if possible.
I put the aluminum one from Summit. It added some more capacity for the rear diff fluid, and it looks cool. The price was also good.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 636 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
