French Assumption:
silverado3500
Actual Conversation of a french carrier captain to British authorities off Dover Bay.
french: Please divert your course 15 degrees to the north to avoid a collision.
British: Recommend you divert YOUR course 15 degrees to the south to avoid a collision.
french: This is the captain of a french navy ship.  I say again, divert YOUR course.
British: No. I say again, you divert YOUR course.
french:  THIS IS THE AIRCRAFT CARRIER CHARLES DE GAULLE, THE SECOND LARGEST SHIP IN THE FRENCH FLEET.  WE ARE ACCOMPANIED BY THREE DESTROYERS, THREE CRUISERS AND NUMEROUS SUPPORT VESSELS.  I DEMAND THAT YOU CHANGE YOUR COURSE 15 DEGREES NORTH, THAT'S ONE FIVE DEGREES NORTH, OR COUNTER MEASURES WILL BE UNDERTAKEN TO ENSURE THE SAFETY OF THIS SHIP.
British: We are a lighthouse.  Your call. :crackup:
    Gkistler
    Gkistler
  • Who's Online   4 Members, 0 Anonymous, 926 Guests (See full list)
