Letter From GM
varmint2506
I received a letter from GM stating that they would extend the warranty on my '97 Tahoe to cover windshield wiper motor. The letter stated that they were not recalling the motor just replacing ones that have problems. I believe it covered most of the '97 truck/suv models. If you have already had it replaced they will refund the money.
Any of you '97 owners having problems with you wiper motor?
I have replaced mine in the 92, and I have several friends that have 96-98 model trucks that have needed them.
Who am I kidding, I only have two friends.
Thanks though, I will let them know, so they can get reimbursed. Or at least check into it.
The letter was specific to '97 models. I'm not sure if they have or will expand that to other year models.
I do know a couple of people that have replaced 97 models wiper motors.
Thanks though. Good info.
GM sends those out all the time. They are voluntary campaign's that are generally VIN# specific, or production date specific.  They don't generally cover a whole years worth of actual continuous production but could cover certain batches from certain years that a certain supplier may have supplied GM with that particular Wiper motor part.
Also, they ARE NOT extending your warranty, rather simply covering the cost of replacing this wiper motor without cost to you.  Don't plan on going in with a couple other problems and expecting warranty coverage.
I've got a whole file cabinet full of these sent to me over the past 7-8 years. :crackup:
Yea it would be nice for them to extend the bumper to bumper. :crackup: They are extending the warranty on the wiper motor only. I have until Feb. 2004 to replace if I have problems. :thumb:
I got the same letter for my '97.  No probs yet though.  Although, I must say, I am VERY disappointed in the wipers themselves.
Dunno if it is the wipers or the truck, but after about 2 months, my Anco Winter blades decided to stop wiping the area in the line of sight in both the drivers and the passengers side.  Maybe I will have to try Bosch blades.
Anyways...the short answer is no.  :-)
A coworker just got his letter today.
It basically says .....if you have:
1. 97 Blazer or S10 p/u
2. 95,96,97 Astro or C/K Crew cab
3. 94,95,96,97 C/K p/u, Tahoe or Suburban
And have had wiper problems.
It goes on to describe a problem with cracked solder joints on the controller circuit board.
I got the letter and it's a little late. I replaced three wiper control boards in my old 95 Silverado. A co worker has a 98 Tahoe and his is bad but isn't covered by the fix in the letter.
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 420 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
