Injector help
I have a 4.8l 2013 silverado and I'm wanting to put bigger injectors in it I already have a bigger pump my question is would 2013 corvette injectors fit they look about the same size is it ok as long as the motor is the same?
What is the need for larger pump and injectors. Also they are not just plug and play. Tuning is needed for whatever non stock injector you install.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,155 Guests (See full list)
