2014 GMC Sierra - Leveling Kit and Tires
Hello all!
I recently purchased a 2014 Sierra Truck and was looking to level it and put tires on it. I would like to hear everyone's thoughts on the safest/best leveling kits to use and what size tires you were able to fit on your truck (20" rims). I'm looking for a leveling kit that is truly leveled and puts the least amount of stress on my front end suspension. I have also have no opposition to raising the rear up for towing my boat.
Lets hear it!
Thanks,
William
Charleston SC
All the leveling kits work the same. Bottom stru spacers are easiest to install. The top strut spacers require removal of the strut and cutting of the mounting studs. As long as you don't exceed 2.5" you're fine with either style.
    bellssn690
    bellssn690
  • Who's Online   2 Members, 0 Anonymous, 522 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
