Bigger Aux Tranny Cooler
Driving around town with the plow on, the tranny temp is running between 150 and 200. I am wondering if a larger cooler would help lower the temp.
Thoughts and suggestions on what a good replacement of the factory installed aux cooler would be?
2005 Chevy Suburban LT 6.0L V8 engine - factory installed aux tranny cooler as part of the towing package - heavy duty fan clutch just installed which has eliminated the engine running hot issue.
Thanks!
I'm guessing the plow is blocking your airflow over the radiators. Maybe electric fans would be a better way?
My trans temp runs around the 130-140 range now, here in FL temps are in the 60-70s. Anything that you would add should help, you just have to have it placed where airflow would be good.
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 817 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
