What news network do you watch?
silverado3500
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Bill O'Reily's show was GREAT last night :thumb:
Opening comment was enough to make you want to salute! :chevy:
Hey!! Kinda biased. Where the heck is CBS? I work for a CBS Affiliate, and noticed they were missing. Not that I think their the best, but they are one of the big three. Is there something I don't know? Am I going to loose my job? :chevy:
I usually watch CNN for news.
    Policeoff01
    Policeoff01
  • Who's Online   4 Members, 1 Anonymous, 745 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
