2004 gmc denali rear suspension
Nope. Simple answer is no. Even if you do manage to go from the multi-link setup to a leaf setup, it will not legally raise capacity. Also the frames are completely different to allow the different transmission, transfer case, and axles. The AWD system and axles will be the weak point if you do manage the suspension change. The 4L60E is not the best transmission for loads either. You are looking at dropping in more money than the vehicle is worth
Hey guy got an 03 gmt800 (yukon slt) and I was curious if there's any cheap or free ways to level out the rear suspension? At the alignment shop my truck sits higher in the front than rear would this make towing a light 14ft single axel trailer difficult? Thanks!
Depends on 2wd or 4wd. If 4wd, turn the torsion bars down
Your truck will tow that no trouble. You could always add a bigger rear block? Pics of truck?
    CaptainDad
    CaptainDad
  • Who's Online   1 Member, 0 Anonymous, 542 Guests (See full list)
