Might sell. Fender flares and wheel spacers
I have Bushwacker rivet style fender flares for a 2014 Silverado 1500 with the 6'6" bed. They are color matched summit white. I also have 1" wheel spacers that came off the 2014 Silverado 1500. They are currently still on the vehicle but I plan on removing them if I get interest in them. They are located in Streator, Il.
Intersted in the spacers. Are the wheel/hub centric? Do they bolt to the hub and then have additional studs for the wheels?
Yes they bolt directly to the hub and have additional studs.
Did you have to cut the studs to use the wheel spacers?
Yes I did cut bout .5" off. I just placed my order today for the new wheel studs. Only $30 at rockauto.com
Ok. So new studs are in the mail. Will most likely be some time next week. And the truck is going in for a detail and fender flare removal on Monday. So they will be for sale shortly.
    bellssn690
    bellssn690
  • Who's Online   3 Members, 0 Anonymous, 905 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
