Steering gear box confirmation
renegadejd
I have a 2000 gmc sierra 1500 and it is very hard to turn right while stopped or moving slow. It turns left with no problems. Also when you turn to the right it hisses.
From what I've found online it is the gear box. I've bought the parts (gear box and pitman arm) but I'd like to get more confirmation that this is the problem. I really can't afford to replace parts for no reason at this time. Thanks.
He is saying you already bought and paid for the parts, so you have already committed to replacing them, or take the restocking charge hit.
There are only three parts to the power steering part of your truck. I say that by lumping all the power assist parts in the steering box to count the box as one part. The other parts are the pump and the hoses. The pump has no idea what direction you are turning, so, that rules out the pump. Ditto for hoses. That leaves the steering box. My guess from far further away than you are from your truck is steering box(unless you want to actually fix the issue inside the box, which I highly doubt), so you can take that with a grain of salt.
With all that being said, I have seen ball joints cause issues with power steering in one direction, as well as not allowing steering to return on its own. The ball joints were seized in the cases I have seen. Not likely the issue here, ball joints rarely seize in one direction only.
Depending on how bad the steering box is, it may have damaged the pump by the box asking for max pressure in one direction(like when you get to the steering stops and keep trying to turn you here that noise) only. Take a look at the fluid in the pump resevoir and see if it is burnt, or it has a nice metallic tone to it(sort of like the colour of a red bass boat or dune buggy). If it does, do not be surprised if the pumps gives out shortly after changing the box. I would get some extra power steering fluid and use the engine to flush the pump out. If you are going to do the pump as well, do the flushing BEFORE you change the steering box to avoid getting crap oil in the new box. To flush, just pull the return line off the pump(the line with a hose clamp on it), drop it into a pan, and turn the steering wheel back and forth.
Awesome doug_scott. I appreciate your help. You confirmed what I have found so far, and answered some questions for me as well.
    Zinister101
    Zinister101
  • Who's Online   5 Members, 0 Anonymous, 597 Guests (See full list)
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
