Qnx... isn't that the OS that RIM used to use and was reluctant to shed? Maybe a good choice ten years ago, but not today.
Upgrade to a more modern OS then lots of things are free, Both current and future. Stay in an old architecture and you are doomed.
Funny thing is that they wrote most of this as custom code, I'm sure. Why would someone ever write these apps, they are all out therE, we use them every day on other devices.
QNX is still a good embedded realtime OS. Sure, you could shove Android in there, and some companies do. The company I work for happens to do just that, and its in some car lines now. That said, when you have a device like this, and you are looking to keep CPU and other HW costs in check because every penny counts (GM's unofficial mantra), a microkernel OS like QNX is the way to go. Especially when there is the QNX car platform that gives you a lot of integration functionality for "free", so I do not believe it the backend stuff is custom code. But just because you have the tools doesn't mean you know how to use them effectively, which leads us the terrible UI and overall performance issues.
Android is already being plagued with malware and other unfavorable software exploits. Do you want your car opened up to that? I don't.
Also, GM needs to control what apps they allow in the car, as anything that overly distracts the driver could very well be their liability. Using a service to hack in other features on the other hand is YOUR liability in the end. Probably why GM hasn't tried to put an end to it.
Bingo.
I suspect (not knowing the exact system hardware in use) it's either underpowered hardware, terribly optimized software, or in typical GM fashion.... both.
  • 7 years later...
I've added a cable that I bought online for about $50 it let's me watch video in motion.
Thing Is, I can't download videos on another SD card. I don't know what format I used on the first one. When I figure it out, I'll post it
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
